  3. Virtuoso continues to crash
  • Replies 10
  • Subscribers 129
  • Views 22225
Miguel V
Miguel V over 6 years ago
I have a colleague who keeps having issues with virtuoso unexpectedly crashing whenever she tries to open a layout in either read or edit mode.  Some cells are fine, but there are some that crash every single time, even tried to jump to a different server or create a new workarea.  I've tried to have her copy the layout in question but the crashing still happens.  Also, it doesn't matter what version of Virtuoso we use, the result is always the same.
    You should contact customer support, and provide the crash log and CDS.log from the session where the crash occurred (ideally produce a few if they are reproducible on different designs). The signature of the crash can often help us identify if it's a known issue that's been resolved in a newer version.You didn't mention which versions are being used or whether these are recent or not.
    The other thing that is worth doing is (from the UNIX prompt) "oaScan -lib theLibName" to see if there is any database corruption in the design that needs fixing.
  • Miguel V
    Miguel V over 6 years ago in reply to Andrew Beckett
    Hi Andrew, thanks for the command.  I tried this running IC version 6.1.6, 6.1.7 and 6.1.8  Just before the crash we get a SIGSEV error and cadence closes, then we get a pop-up asking us to view the report.  How do I repair any corruption?  I ran the scan and I get numerous ERROR SCAN-211 or 93 errors on the cells that are giving us problems:
    ERROR SCAN-211  Repair needed for inconsistent appData reference on a inst
    ERROR SCAN-211  Repair needed for inconsistent appData reference on a shape
    ERROR SCAN-211  Repair needed for inconsistent appData reference on a via
    cellview <LIB>/<CELLNAME>/layout 'maskLayout'
    -data model 0 saved by an app compiled against 22.60.007 running 22.60.007
    -platform linux_rhel60_64 gcc_6.3.0
    Andrew Beckett over 6 years ago in reply to Miguel V
    If you run oaScan with the -repair option it will fix these...
    This is assuming that it's the info found during the oaScan which is causing the crash. If it still crashes after the repair, you absolutely should contact customer support (I'd also suggest using IC618 to open the repaired data, in case it's an older buggy version which is introducing the inconsistent appData).
  • Miguel V
    Thank you, that worked like a charm.  Issues were repaired and now the cells open up without crashing, thanks.
  • Miguel V
    Miguel V over 5 years ago
    I'm coming back to this.  The error is popping up again and this time when I run oaScan, I get the following error and the repair also terminates with a SIGSEGV error just as cadence outputs when it crashes...
    Running: oaScan -lib <the-library> -repair
    Started: Mon Mar 30 10:53:18 2020 (Hostname: <server>)
    Cellview <library>/<cell-name>/layout_test_new 'maskLayout':
    - data model 0 saved by an app compiled against 22.60.007 running 22.60.007
    - platform linux_rhel60_64 gcc_6.3.0
    FIXED REPAIR-93: Repaired the inconsistent appData reference on a inst.
    FIXED REPAIR-93: Repaired the inconsistent appData reference on a shape.
    FIXED REPAIR-184: Repaired the inconsistent InterPointerAppDef leVioFig2 of marker on inst.
    FIXED REPAIR-184: Repaired the inconsistent InterPointerAppDef leVioFig1 of marker on inst.
    An internal error SIGSEGV has occurred and oaScan must exit.
    Note that some databases may not have been processed.
    Report this error through your support channel.
    -Miguel
    Andrew Beckett over 5 years ago in reply to Miguel V
    Hi Miguel,
    Apologies for this being blocked as spam initially - the repeated text in the message is what was used to indicate that it might be spam. Obviously this wasn't, which is why it comes to moderation. Anyway, if you're using a current oaScan (say, from the latest IC618/ICADVM181 ISR, ISR10), then please contact customer support, as the message suggests.
  • Miguel V
    Miguel V over 5 years ago in reply to Andrew Beckett
    Yes, I figured that's what happened since I know it wasn't "offensive".  It's weird, I deleted the cell causing that issue and ran oaScan again and it completed without the SIGSEGV error.  The issue now is when my coworkers makes a few edits and goes to save, cadence crashes yet again.  She can open it back up just fine and make more edits, the issue is the crash every time she goes to save it.  She's working remotely through VPN so not sure if that is somehow contributing to the problem because in her words, this doesn't happen when she works from her office.
    I rather doubt the VPN has anything to do with it.
    Which IC sub-version are you using, and what does "oaScan -version" report? I found some recent fixes related to InterPointerAppDef (this might not be the issue, but they are also reported in your log) but let's see...
  • Miguel V
    We are using IC6.1.8 64b.83.
    "oaScan -version" reports the following:
    Tool: oaScan oaScan_p047 (22.50)
    Hi Miguel,
    You have the base release of IC618 there (and the oaScan that comes with it) - this is 18 months old. I'd suggest first starting by getting IC618 ISR10 installed (the latest version on downloads.cadence.com) and seeing whether oaScan from that build works - you may need to use that subversion too for editing if it fixes the underlying data corruption problem.
    If that doesn't fix it, you'll really need to contact customer support.
