  3. Error with simulation in IC6.1.7-64b.78 with spectre15.1...
  • Subscribers 125
  • Views 15317
Error with simulation in IC6.1.7-64b.78 with spectre15.1.0.284.isr1
shrubbroom
shrubbroom over 5 years ago
I have installed IC617 and MMSIM151 in Ubuntu 18.04.4 LTS. Everything gose well until I start simulation and launch ADE L. Once upon I open the ADE window, a warning is thrown out.
*WARNING* The Virtuoso Analog Design Environment (ADE) creates a user interface (UI) to match the features of the particular
version of MMSIM you are using. The software could not find the 'feature file' in the MMSIM hierarchy that lists the features
available in this version of MMSIM. You might be using a wrapper script around spectre such that 'which spectre' returns
your wrapper script and not spectre in the MMSIM hierarchy. For now, ADE will create a UI to match the latest version
of spectre. If you are using an older version and do not want to see the UI for features that are not available in
that version, you can set the following variable according to spectre version you are using:
setenv SPECTRE_FEATURE_FILE /home/pathForMMSIM/tools/spectre/etc/files/spectre.dat
I followed its davice and execute the last command by:
export SPECTRE_FEATURE_FILE=/mnt/d/cadence/MMSIM/tools/spectre/etc/files/spectre.dat
However this doesn't work and once I open the ADE window, this warning continues to throw out with two error:
Loading cdf.cxt
Loading AMSPlugin.cxt
*Error* concat: illegal argument type - nil
*WARNING* (DEBASE-102079): A SKILL error occurred in function artMenuTrigger
*Error* append: argument #2 should be a list - t
I opened the stacktrace and try to figure out the problem of error, these are the stacktrace result at error:
<<< Stack Trace >>>
(... in _amseGetCurrentSession ...)
(... in _isEdenSession ...)
(... in artiSetWindowDataDir ...)
(... in artSetWindowDataDir ...)
(... in sevSetWindowDataDir ...)
(... in sevSetSchematicEnvProperties ...)
(... in sevSetSchematic ...)
(... in sevStartSession ...)
(... in sevSchematicArtistPulldownMenus ...)
apply(artSchematicArtistPulldownMenusFunc() list(args))
let((simulatorchosen design) if(((args->window)->sevSession) then (simulatorchosen = sevSimulator(((args->window)->sevSession))) else (design = sevDesignInSchematic((args->window))) (simulatorchosen = _asiGetDefaultSimulator(car(design) cadr(design) caddr(design)))) cond(((simulatorchosen == "ams") unless(deFindPlugin('amsaAMSPlugin (args->window)) _artInstallPlugin((args->window) 'amsaAMSPlugin))) (rexMatchp("Verilog$" simulatorchosen) unless(deFindPlugin('artVerimixPlugin (args->window)) _artInstallPlugin((args->window) 'artVerimixPlugin))) (t when(deFindPlugin('artVerimixPlugin (args->window)) deRemovePlugin((args->window) 'artVerimixPlugin)) when(deFindPlugin('amsaAMSPlugin (args->window)) deRemovePlugin((args->window) 'amsaAMSPlugin)) when(deFindPlugin('ddsgHEDPlugin (args->window)) deRemovePlugin((args->window) 'ddsgHEDPlugin)))) apply(artSchematicArtistPulldownMenusFunc() list(args)))
(... in _deApplyTrigger ...)
(... in unknown ...)
funobj@0x18cde638()
(... in _dePullTrigger ...)
(... in _deCallMenuTrigger ...)
(... in __deMakeBannerMenus ...)
(... in __deInstallNewAppInWindow ...)
(... in __deInstallApp ...)
(... in deInstallApp ...)
deInstallApp(hiGetCurrentWindow() "analogArtist-Schematic")
<<< Stack Trace >>>
It seems that the two error both comes from the
which troubles me much since I have no idea of how to continue my debug. It would be kind of you to give me some hints or help me figure out this issue.
    Several things here:
    1. We do not support Ubuntu 18; there was limited support for Ubuntu 14 in the past (not the IC or MMSIM streams though), and we're dropping that support in releases from 2020 anyway.
    2. You shouldn't need to set the feature file - all you should need to do is ensure that you have <MMSIMinstDir>/bin or <MMSIMinstDir>/tools/bin in your path (it would be better to use a more recent SPECTRE version anyway; the release stream changed name, and is now SPECTRE - there's been SPECTRE16.1 17.1 18.1 and 19.1 since then).
    3. I've no idea why you're getting that error. My guess is that maybe you've got some obsolete spectre menus file in your working or home directory? Can you type (at the unix prompt): cdswhich menus/spectre.menus and see that it returns?
    Either way, you're using old versions on an unsupported platform. Not a good idea...
  • shrubbroom
    shrubbroom over 5 years ago in reply to Andrew Beckett
    Dear Andrew,
    By executing $which spectre I got a return value:
    /mnt/d/cadence/MMSIM151/tools/bin/spectre
    I also checked the <MMSIMinstDir>/bin and <MMSIMinstDir>/tools/bin, and they both exists. Does these reveals that I had proper spectre installed?
    Then I tried to execute cdswhich menus/spectre.menus, but it returns with:
    WARNING: HOST <DESKTOP-R1A5OUE> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.
    For More Info, Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.
    Info (cdswhich): 'menus/spectre.menus' was not found.
    I think maybe turn to CentOS 7 is a better way since we have got virtuoso and spectre successfully installed in the server with CentOS.
