  3. Question on PSS+PNoise simulation for a Track and Hold ...
  • Replies 11
  • Subscribers 136
  • Views 18653
Question on PSS+PNoise simulation for a Track and Hold circuit
YutaoLiu
YutaoLiu over 5 years ago
Hi everyone,
I am studying how to run PSS+PNoise sim to get total output noise of a Track and Hold circuit.
I am using Virtuoso version ICADVM20.1-64b.500.15 for simulation.
Below is my test bench, in which the switch is driven by a 8GHz 25% duty cycle clock. The closed switch resistance is 0.1Ohm, while the open resistance is 1T Ohm. And the RC time-constant is 15GHz, which is higher than the Nyquist frequency (4GHz).
In document "Simulating Switched-Capacitor Filters with SpectreRF" , it is written that the total noise of T/H circuit is kT/C, which is 41.4nV^2 in this case.
I expect that the noise higher than 4GHz would be folded back into 0~4GHz, so I set the output frequency is from 1~4GHz. And to get a more result, maximum sideband was set as 50 (Because 4GHz *50= 200GHz >> 15GHz).
However, the total noise integrating from 1Hz to 4GHz is only 27nV^2. Moreover, the total noise increases as the duty cycle decreases.
Did I misunderstand anything about the total noise of T/H or do anything wrong in the simulation setup?
Thanks and regards,
Yutao
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago +1
    You only get all the noise in the frequency range up to half the "Beat Frequency" if you use a sampled pnoise analysis. Take a look at the stop frequencies of unsmpldNoise and smpldNoise in Listing 1 of…
    Andrew Beckett over 5 years ago in reply to YutaoLiu +1
    Hi Yutao, I don't have bandwidth this week to look into your questions or issues in depth, but a quick answer to your points above: a) If the circuit itself folds noise, then that is handled by timeaverage…
    ShawnLogan over 5 years ago in reply to Andrew Beckett +1
    Dear Yutao, Please allow me to try to add to both Andrew's and Frank's very valuable comments...maybe my comments will not but will let you be the judge! YutaoLiu said: a. it seems that noise folding…
    Yutao,
    If you don't want to set the sampling point based on a signal crossing a given threshold, then edge crossing (or edge delay) don't really make sense. Instead used the sampled phase. You will need to have at least one point per period (I think), but you can then just also list the specific times (there can be more than one) you want to sample at in the Add Specific Point field.
