  3. Post Layout simulation for multi-finger transistors
  • Replies 11
  • Views 18708
Senan
Senan over 5 years ago
In the post layout simulation for a transistors built of number of segments/fingers, the simulated current in cadence shows only the current per one segment, then I have to multiply it myself to get the complete value,
Is there any way to tell cadence that those individuals should be combined.
Thank you
Best Regards
    Not enough detail to know what you've actually done here...
    ShawnLogan over 5 years ago in reply to Andrew Beckett +1
    Dear Senan, Senan said: In the post layout simulation for a transistors built of number of segments/fingers, the simulated current in cadence shows only the current per one segment, then I have to…
    ShawnLogan over 5 years ago in reply to Senan +1
    Dear Senan, Senan said: This is what I meant to say " When there is a mosfet with more than one finger, the annotation on the schematic displays only for a single finger (not for all fingers). ", this…
    Dear Andrew,
    Andrew Beckett said:
    The last portion of the version number is the ISR number, and IC6.1.8 tracks ICADVM18.1/ICADVM20.1 (in the advanced methodology stream, it switches from 18.1 to 20.1 at ISR14 - but it still remains aligned).
    Thank you very much!! The version coding is something I have never totally understood! As usual, I appreciate your education (again)...
    Shawn
