  3. Config simulation-Netlist generation failed
  • Replies 11
  • Views 21394
Yongqi Hu
Yongqi Hu over 4 years ago
When I run config simulation, it shows that netlist generation failed as shown in the bottom figure, so I change the simulator to AMS, the netlist can be generated successfully, I want to know if the ADE's simulator is set to spectre, config cannot support netlist generation where cells are text, or there are other ways to solve this problem? Hope someone can help me, appreciate that!
    Andrew Beckett over 3 years ago in reply to Yongqi Hu
    By posting that it’s solved, I didn’t mean editing the original post to remove all the content and in that saying it’s solved. If you’re going to do that you might as well have deleted it.
