  3. passing global variable to ADE output
  • Replies 12
  • Views 19823
TommasoF
TommasoF over 4 years ago
Hi all,
in ADE assembler I defined a global variable named "active_port" which value is changing from corner to corner
The ADE test is made up by a DC+ SP simulation. In the ADE outputs I defined a bunch of equations as shown below.
Now, my wish would be to have the index of the equations to change according to the corner, like shown in the example here below, where instead of having the number "hard-coded" I enter the variable I desire.
When evaluating the equation I get an "eval err". I tried in several ways using "value", "leafValue" but so far it didn't workout.
So then I tried to evaluate the variable itself
and  I see that the variable has some independent variable included (see green arrow below), which probably cause the trouble I have. I was looking for ways to just extract the scalar value being displayed, but I found no means to do it.
I hope the problem statement is clear. Any idea on how to fix it ?
thanks!
Tommaso
  • Saloni Chhabra
    Saloni Chhabra over 4 years ago in reply to TommasoF +1
    Hi, I checked that an enhancement CCR is already in place for this request, but it isn't yet planned. As a workaround, can you try defining the function int around VAR("") e.g. spm('sp 1 int(VAR…
    Andrew Beckett over 4 years ago in reply to TommasoF
    TommasoF said:
    Is there any chance to get it run also in Assembler ?
    As Saloni mentioned before, there's an enhancement CCR to get this resolved. Please contact customer support and request that a duplicate is filed (I didn't check what the CCR number is).
  • TommasoF
    TommasoF over 4 years ago in reply to Andrew Beckett
    this has fixed the problem
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000005cdBYEAY&pageName=ArticleContent
