  3. Magnitude value in AC simulation with Cadence Virtuoso
  • Replies 11
  • Subscribers 136
  • Views 27108
Senan
Senan over 3 years ago
I would like to ask you about the "Magnitude" value we define in the input sine signal when performing the AC simulation,
I usually set it to "1" so I can easily interpolate the output signal as the gain of my amplifier as simply the output is equal to gain when input is one.
However, it just came to my mind if this value has an effect on the amplifier small signal characteristics or not, just I want to verify this point.
Thank you
Regards
    ShawnLogan over 3 years ago +2
    Dear Senan, Senan said: I usually set it to "1" so I can easily interpolate the output signal as the gain of my amplifier as simply the output is equal to gain when input is one. This is correct. …
    Andrew Beckett over 3 years ago in reply to Senan +1
    Senan said: If I want to make comparable practical measurement, do I have to use a test signal with a small amplitude? I found however, even with small signal test of 100 mV and large gain setting, the…
    ShawnLogan over 3 years ago in reply to Andrew Beckett +1
    Dear Senan, Senan said: If I want to make comparable practical measurement, do I have to use a test signal with a small amplitude? I found however, even with small signal test of 100 mV and large…
    ShawnLogan over 3 years ago in reply to Senan
    Dear Senan,
    I am just happy to read it was a little helpful to you - so thank you for letting us know!
    Senan said:
    nd your suggested balun, it is indeed masterpiece to see a balun with such a range, I could have find some people selling it in ebay and I requested them to buy it, looking very interesting.
    Great! I would definitely recommend picking up a couple - I used them extensively in measurements as did others in our team. Good luck Senan!
    Shawn
