  3. Adexl - dynamically stop transient run on event trigger
  • Replies 11
  • Views 7175
firebolt
firebolt over 3 years ago
I tried to use MDL control as mentioned in support link here. It works fine for event tigger but not for additonal 10us delay. Please help here.
tran_autostop.mdl file contents:
alias measurement tran_autostop
export real rise2
run tran
rise1=risetime(sig=V(clk_en), initval=0, inittype='y, finalval=1.8, finaltype='y, theta1=10, theta2=90)
rise2=rise1+10E-6
run tran_autostop
Trasient Options > Misc
Test > right click options > MDL Control
    Andrew Beckett over 3 years ago +1
    You're lucky that I responded to this given that the MDL script is in Comic Sans . That's a cardinal sin (I probably should state that in the forum guidelines!). Just kidding... If you read the documentation…
    Andrew Beckett over 3 years ago in reply to firebolt +1
    Yes. This is covered in the MDL manual that I mentioned earlier in the section headed Accessing Netlist or Model Parameters . You wouldn't use a SKILL function (VAR("vdd")) in an MDL file; SpectreMDL knows…
    That's not going to work. I'm assuming you're talking about adjusting an ADE output expression (using clip). For a start, you're not exporting clkdelay or stop_time, and even if you were, the dimensions…
  • firebolt
    firebolt over 3 years ago in reply to Andrew Beckett
    How to access CCR page? I was able to gate vdd_noise with clkok using bsource expression in the testbench only.
