  3. How to simulate Large signal bandwidth of amplifier
  • Replies 18
  • Subscribers 136
  • Views 19888
Senan
Senan over 3 years ago
I would like to ask you about how to simulate the large signal bandwidth of amplifier in cadence. I know the basic test that requires to sweep a large signal sinusoidal condition and record the output frequency response (with defined closed loop setting) and then determine the bandwidth straight forward. But I want to make this operation more automated like a real Bode blode measurement with by sweeping the sinusoidal signal frequency.
Does Cadence Virtuoso support a a sine source with sweeping frequency?
Thank you in advance for your help
Best Regards
    ShawnLogan over 3 years ago +1
    Dear Senan, Senan said: But I want to make this operation more automated like a real Bode blode measurement with by sweeping the sinusoidal signal frequency. Does Cadence Virtuoso support a a sine…
    Andrew Beckett over 3 years ago in reply to ShawnLogan +1
    Doing this with transient is always going to be a pain. If you truly need the large-signal frequency response (presumably because the circuit is not responding linearly at the input signal level you've…
    ShawnLogan over 3 years ago in reply to Senan +1
    Dear Senan, Senan said: The first one I am gonna try is to use the sine wave with parametrized frequency, I will run the transient simulation for several periods to be sure that amplifier is settled…
  • Senan
    Senan over 3 years ago in reply to ShawnLogan
    Dear Shawn,
    Thanks a lot, that was a wonderful help, it is working now perfectly :)
    I could now simulate the large signal bandwidth of my circuit. For the purpose of the test I have verified it with a simple single poleLPF circuit,
    I have defined a math function to calculate the gain in db by dividing the peak-to-peak value of the output signal to the input as you can see from the image below, the clip function helped me to take the clean part of the signals.
    One thing remaining for this approach is how to plot the phase response of the circuit from this time domain simulation.
    Thank you very much once again and I do appreciate your kind help and support
    Regards
    Dear Senan,
    Excellent and very good work Senan!! There are other means to more precisely determine the large-signal gain, but if the amplitude of your input and output signals are sufficiently large with respect to numerical noise, and your amplifier does not produce significant harmonic distortion, and the accuracy requirement for your transfer function/bandwidth estimate is under 1 dB, your method is probably fine.
    The phase response can be estimated using a series of time domain measurements of the normalized input and output waveforms if you're up for another "challenge". I will send you an example shortly.
    Shawn
    ShawnLogan over 3 years ago in reply to ShawnLogan
    Dear Senan,
    I've completed an example of the methodology using a 1 MHz lowpass single-pole filter and documented a few notes on the masher in which the phase is computed from the normalized input and output waveforms (assuming sinusoidal). They may be a bit brief, but I was trying to get you something quickly to consider. I hope this helps.
    Shawn
    transfer_function_gain_phase_1 MHz_example_sml_021423.pdf
    Dear Senan,
    I took some time to better explain the algorithm to determine the large signal transient response when the input and output waveforms are nearly sinusoidal and corrected one error in my prior note. Please  ignore the prior document to avoid any confusion and refer to the following document:
    If I try to include this as a link, it will be flagged as spam, so I have to include it as a graphic - sorry! However, if you just enter the first part of the address into your browser and append it with:
    /s/z7bljbf3l539u87/transfer_function_gain_phase_1%20MHz_example_sml_021523v1p1.pdf?dl=0
    it may be less "painful" to access the note. My apologies for the added effort Senan!
    Shawn
    Dear Senan,
    I updated the note to include the manner in which the gain was computed to version 1.2. Unfortunately, the address was changed even thought I attempted to keep it the same. The last segment of the updated note address (and correct address) is:
    /s/9ok4tyy8iz8sp4i/transfer_function_gain_phase_1%20MHz_example_sml_021623v1p2.pdf?dl=0
    Shawn
    transfer_function_gain_phase_1 MHz_example_sml_021623v1p2.pdf
  • Senan
    Dear Shawn,
    I am so grateful for your great help and dedicated time to answer my post. I will soon recover my access to Cadence after my vacation and give you feedback on your suggested method.
    Best Regards
    Dear Senan,
    I just hope it is somewhat helpful - but vacation must come first Senan! Enjoy!
    Shawn
