  3. Modelling and design of an optical receiver
  • Replies 12
  • Subscribers 137
  • Views 14474
TUKA
TUKA over 3 years ago
Dear all,
I am working on the design of an optical receiver consisting of a Transimpedance amplifier (TIA), a two stage variable gain amplifier (VGA) and an output buffer.
I am initially modelling both the TIA and the VGA using a simple verilogA behavioral model to gain some insights. I have a question regarding my behavioral model:
The TIA gives me input referred noise current and the VGA gives me input referred noise voltage. Is there any formula to convert these input referred noise quantities into an equivalent noise figure for the whole system?
Thanks!
  • TUKA
    TUKA over 3 years ago in reply to ShawnLogan
    Dear Shawn,
    ShawnLogan said:
    I just hope they help!
    Yes, it has worked. I have used the same old flicker_noise( ) function to plot shot noise that varies with f^2.
    As you mentioned, I plotted flicker noise that varies as 1/f^(-2). I can see the parabolic shape in my plot.
    Thank you so much for your elaborative suggestions throughout this post.
    Tuka
    Andrew Beckett over 3 years ago in reply to ShawnLogan
    ShawnLogan said:
    I am not sure if this was Cadence's motivation for their definition of the flicker_noise() function
    Shawn,
    It's not really us - this is part of the Verilog-AMS standard. However, many device models have similar ability to control the exponent of flicker noise (see the ef model parameter of, say, mos3 in spectre).
