  3. i want to read (2 dimensional array) , not only the first...
  • Replies 13
  • Views 13986
i want to read (2 dimensional array) , not only the first line
Hagar Hendy
Hagar Hendy over 3 years ago
i have text file (3x3) as shown below in the screenshot , and when i wrote the below code, it only reads the first line,  however i need to read all number ( 2 dimensional array).
the first line will be on port A, second line on: port b , third line on: port C
module read_file (a,b,c);
output a,b,c;
electrical a,b;
integer in_file_0,data_value, valid,count_0,count_1,count_2,retval;
real A,B,C,v0_int,v1_int,v2_int;
// real int_value,v0_int,int_valu;
analog begin
@(initial_step) begin
in_file_0 = $fopen("/home/hh1667/ee610/my_library/read_file/data2.csv","r");
if($fscanf (in_file_0, "%f,%f,%f", A,B,C)==3) begin
count_0= A;
$display("%f", A);
count_1 =B;
$display("%f", B);
count_2 =C;
$display("%f", C);
end
//$display("%f,%f,%f", A,B,C);
v0_int = A;
v1_int = B;
v2_int = C;
//$display("%f,%f,%f", v0_int,v1_int,v2_int);
end
// V(a) <+ A;
// V(b) <+ B;
end
endmodule
    Andrew Beckett over 3 years ago in reply to Hagar Hendy +1
    The if does not need an end because there's no begin in the body of the if statement. You only need begin/end pairs if you have multiple statements, and the index++ is a single statement. I do not get…
    OK, so you're using an old Spectre version (from 6 years ago), and also an old IC version. It seems that the Spectre Verilog-A parser handles this code from a SPECTRE19.1 version (I tried with the latest…
    My guess is that your data2.txt file has Windows line endings. Can you show the output of: cat -vet /home/hh1667/ee610/my_library/read_file/data2.txt (in a UNIX terminal window)? My guess that the…
  • Hagar Hendy
    Hagar Hendy over 3 years ago in reply to Hagar Hendy
    also i am  student, and i am using this version through my institute, so i don't know how to use the newest version, or i think i have to let my advisors know that version that i am using is old.
    My guess that the solution is to run:
    dos2unix /home/hh1667/ee610/my_library/read_file/data2.txt
    to convert the line endings and it should then work. I tested the file with Windows (DOS) line endings, and it failed with the same error that you saw (with SPECTRE16.1). With newer Spectre versions, it worked fine even with the Windows line endings.
  • Hagar Hendy
    Hagar Hendy over 3 years ago in reply to Andrew Beckett
    t:
    yeah, it works thanks a lot for your help, appreciate your support
