  3. Limiting the length of a vector in VIVA
  • Subscribers 129
  • Views 6250
CSCNalu
CSCNalu over 2 years ago
Hi
Is there a way to get an arbitrary length of samples using the "value" command?  I have it set up to gather from the starting point and using the ?period argument I have it resampling but I only need 128 (but probably want ~140) samples and it's giving me the rest of the waveform.  As I'm asking this I realize I can probably do a clip then the value command but are there other ways?
Chris
    Chris,
    You could just use the sample function instead?
