  3. How to copy designs to different machines?
  • Subscribers 130
  • Views 8207
Doronzzz
Doronzzz over 2 years ago
I am trying to copy the OTA I designed from my local workstation to a remote server. I just opened a new project on the server and manually copied the sizing of each transistor. The strange thing is that the two designs has different DC operating points...
The PDKs on the two machines are both from smic 180nm technology, but I don't know if they are exactly the same. The transistor models I used have the same name "n18_ckt", so I assumed they are the same model. I will check the model parameters after DC simulations next, to see if the models are the same indeed.
So my questions are:
1) What might possibly cause this problem?
I've checked the process corner used on the two machines, they are both called xxx_tt. The simulation temp are the same (25 degrees). What else could affect the outcome of a simulation?
2) What is the recommended way to copy designs across different machines?
Is there something like Git on Cadence?
Thanks in advance.
    ShawnLogan over 2 years ago
    Dear Doronzzz,
    Wow! A lot of questions and no firm answers from me based on the information you provided, but I can add a few suggestions. I am sure other experts who monitor this Forum may have other and, perhaps better, suggestions.
    1. If the DC operating points of two presumably identical schematic based netlists are different, there are numerous causes.
    a. First, compare the input.scs files of both simulations - i.e, compare the input.scs file generated in your local workstation environment and the input.scs file generated on the remote server. The "input.scs" file is contained in the netlist directory.  Based on your intent, the two should be identical. If not, study your two schematics and determine if there is a difference responsible for the difference.
    b. Compare the runSimulation files (also in the netlist directory) for both your local workstation and remote server. This file contains the full set of spectre options. Verify that the same options are used for both simulations.
    c. Compare the two spectre.out log files for the two simulations. Specifically, verify the versions of the Cadence tools used is identical and that they both are using the same simulator (i.e, spectre, spectre +aps, or spectre ++aps). You should also be able to tell the version of the model files used and hence verify that the model versions are identical for the two simulations.
    As an example, in a sample spectre.out file I happen to have, the second line states the Cadence tool version as:
    Spectre (R) Circuit Simulator
    Version 20.1.0.382.isr12 64bit -- 5 Nov 2021
    Further down in the file is the simulation line, for example:
    Command line:
    /tools/MMSIM/20.10.382.ISR12/Linux/tools/bin/spectre -64 input.scs \
    +escchars +log ../psf/spectre.out -format psfxl -raw ../psf \
    +aps=conservative +mt=lsf +lqtimeout 0 -maxw 5 -maxn 5 -env ade \
    +disk_check=100e9 -ahdllibdir \
    There should also be some indication of the model file(s) used which often contains the model version number in its path.
    2. You might also try copying the input.scs file and the runSimulation files from one environment to the other and manually run the command line to verify the copied input.scs and runSimulation files produce the same simulation results.
    Using the Library Manager is a far more efficient means of copying one schematic from one library to a different library. While I do not believe Cadence offers a tool for version control, there are third parties that provide version control that work flawlessly with Cadence's Library Manager.
    Shawn
  • Doronzzz
    Doronzzz over 2 years ago in reply to ShawnLogan
    Hello Shawn,
    Thanks so much for your suggestions!
    I compared the model versions and found this to be the cause of the problem. The two PDK versions do have some differences, I didn't expect them to make a huge difference, even though they belong to the same technology node.
    I'll check other things you've mentioned as well. I believe they will be of great help in understanding how simulations work.
    Thanks!
    Doronzzz
    ShawnLogan over 2 years ago in reply to Doronzzz
    Dear Doronzzz,
    Good detective work! I am happy to read you found the source of the discrepancy in operating point results - and thank you for letting us know too!
    Shawn
