  3. use $cds_set_temperature in verilogams report “...libvpi...
  • Subscribers 129
  • Views 6389
use $cds_set_temperature in verilogams report “...libvpi.so...” error
Ring Lewis
Ring Lewis over 2 years ago
Hello, everyone!
I try to use $cds_set_temperature() function from this post:  Verilog-A control of temperature, report error:
Unrecognized system task or function....
libvpi.so: cannot open shared object file: No such file or directory or file is not valid ELFCLASS64 library
libpli.so: cannot open shared object file: No such file or directory or file is not valid ELFCLASS64 library
Is any $LD_LABRARY_PATH should I set to use the funciton  $cds_set_temperature()?
(IC617, spectre 20.1, xcelium 18.03)
Could any help, thank you!
