  3. Unable to see the commands on CIW window.
  • Subscribers 129
  • Views 6813
Arokia
Arokia over 2 years ago
Hi All,
Generally, when I used to do any action on Virtuoso Layout, its corresponding command would appear on the CIW window. It would be even a simple "zoom in" using "mouse scroll up" or "zoom out" using "mouse scroll down", or it could be turning off all the layers using the "NV" button on the "Palette" or the "AV" button on the "Palette".
Previously I could see these commands ie corresponding skill functions on the CIW window when the action takes places in the Virtuoso Layout. But now I'm unable to see it.
May I please know if any kind of setting in virtuoso needs to be enabled, if so Kindly let me know.
Arokia Bharat
    Options→Log Filter in the CIW controls what you see in the CIW. You need the Accelerated Input checked to see commands triggered by menus and bind keys etc.
  • Arokia
    Arokia over 2 years ago in reply to Andrew Beckett
    Thank you so much ! now I can set all the bindkeys Slight smile
