  3. process corner simulation
  • Subscribers 125
  • Views 6684
liangqunshan
liangqunshan over 2 years ago
Hello everyone, I encountered a problem during the process corner simulation as shown in the following figure
And received the following prompt:
WARNING (EXPLORER-1910): Could not create the directory //.tmp_student1/ in order to store temporary scripts.
The scripts will be stored in the directory /.
Check if user has permission to create these directories.
Alternatively, the Cadence variable
envSetVal("adexl.distribute" "jobFileDir" 'string "<new_path>")
can be set to store the temporary files in an alternate location
WARNING (EXPLORER-1947): Could not generate unique number to generate unique directories to store temporary scripts and log files.
These files will be stored in a directory which may be shared by other processes.
WARNING (EXPLORER-1910): Could not create the directory //logs_student1/logs-1 in order to store temporary scripts.
ERROR (EXPLORER-1927): Could not create the command script //runICRP19441
Check if the directory exists and has the required permissions to create file.
 Moreover, this problem also occurs when I use ADE XL for simulation,there was no similar problem in the previous simulation,do anyone know how to solve it ?
    A wild guess - are you running in a working directory that you don't have write access to?
  • liangqunshan
    liangqunshan over 2 years ago in reply to Andrew Beckett
    Hello,Andrew Beckett  !
    Thank for for you help ! I am running virtuoso in a directory where I have read ,write and execute permissions . However , just as this issue has arisen for unknown reasons,now for unknown reasons ,I  am now able to conduct process corner simulations again. So amazing!
    Regards
    Qunshan Liang
