  3. Error "Unsupported tolerance specification" while referencing...
  • Subscribers 129
  • Views 731
Error "Unsupported tolerance specification" while referencing a pspice level 2 transistor model
Jonas Buehler
Jonas Buehler over 2 years ago
Hi all,
I am trying to create a simulation with Spectre 20.1.0.534 which contains a PSPICE model of a discrete transistor. This transistor model (level=2) contains tolerance parameters like lot/4/uniform=. When I try to reference this model with pspice_include, the error "Unsupported tolerance specification" is raised. Is there any workaround to get models with such tolerance parameters running?
Thank you in advance!
Jonas
    Jonas,
    Can you point me at a public location with the model in question for the discrete device? Or share just a small portion of the mode with the lot/4/uniform= statement (I'm not familiar with that syntax). Normal statements like this:
    .MODEL RTRACK RES (R=1 DEV/GAUSS 1% LOT/UNIFORM 5%)
    just generate a warning (I'm assuming you're including the model using pspice_include ?)
