  3. generating an output sNp file, when an sp simulation is...
  • Subscribers 129
  • Views 2178
generating an output sNp file, when an sp simulation is used in concert with a transient sim's actimes
frankp
frankp over 2 years ago
Hello Cadence help,
In virtuoso ICADVM20.1 Assembler:
I am currently running a transient simulation with actimes populated (several time indexes), that is linked to an sp simulation (acnames=[sp]). The said sp simulation is setup to generate an output file "myfile.s2p".
The problem is that although several sp simulations are run (one per time index), only one sp output file is created.I would like for an output sp file to be created per each actimes time index.
I may be able to get around this problem by using corners where actimes is parametrized using a design variable, but even if that would work it forces me to run the same transient simulation for as many transient indexes that I have. Assuming that I had 100 time indexes, I would end up running the same transient simulation 100 times .... which will make for a very top-heavy simulation. Is there a way to generate N sp output files, but only running once the transient simulation ?
Ideally, I would like for my sp output files to be suffixed with the time index. E.g:  myfile.s2p.1.061n,    myfile.s2p.1.064n,  myfile.s2p.1.067n,  etc.
Thank you
Frank
Excerpt from input.scs file:
tran tran stop=Tstop write="spectre.ic" writefinal="spectre.fc" \
    annotate=status strobeperiod=1p actime_pair=no actimes=[1.058571429n \
    1.061547619n 1.06452381n 1.0675n 1.07047619n 1.073452381n 1.076428571n \
    1.079404762n 1.082380952n 1.085357143n 1.088333333n 1.091309524n] \
    acnames=[sp]
sp sp ports=[PORT1 PORT2] start=10 stop=100G dec=10 readns="spectre.fc" \
    prevoppoint=yes readforce="spectre.fc" file="myfile.s2p" \
    annotate=status
    Hi Frank,
    On the sp analysis, set file="myfile%A.s2p" . That will cause the files to be named by the sub-analysis name, so it would end up with:
    myfiletran-000_sp.s2p
    myfiletran-001_sp.s2p
    myfiletran-002_sp.s2p
    myfiletran-003_sp.s2p
    myfiletran-004_sp.s2p
    myfiletran-005_sp.s2p
    myfiletran-006_sp.s2p
    myfiletran-007_sp.s2p
    myfiletran-008_sp.s2p
    myfiletran-009_sp.s2p
    myfiletran-010_sp.s2p
    myfiletran-011_sp.s2p
    I know it doesn't have the time in, but they are at least sequentially named.
  • frankp
    frankp over 2 years ago in reply to Andrew Beckett
    Thank you Andrew. That did the trick!
    If need be, I can use the info in psf/logFile to parse the file names and rename them with the time index.
