  3. Adding a new parameter to the cdf for each cell in a li...
  • Subscribers 129
  • Views 5598
Adding a new parameter to the cdf for each cell in a library
GuiXZatS
GuiXZatS over 2 years ago
I need to add a new property to the CDF fro every cell in a library.
The new property name is "model" and the value must be the same as the Cell Name.
I am trying with this:
MYLIB=ddGetObj("LIBRARY")
foreach(cell MYLIB~>cells
   MYCDF=cdfGetBaseCellCDF(cell)
   MYNEWPAR = cdfCreateParam(MYCDF ?name "model" ?type "string" ?defValue "VALUE" ?units "don't use" ?parseAsNumber "no" ?prompt "Model Name" ?editable nil ?storeDefault "no" ?parseAsCEL "yes" )
   cdfSaveCDF(MYCDF)
When coping and pasting these lines in to the Virtuoso command line, a have this error:
dd:0x36a45820
*WARNING* Invalid CDF data entry
*Error* cdfiCreateParam: Invalid CDF data entry.
Note that the the parameter "?defValue" in cdfCreateParam is fixed, as I do not know how to obtain the cell name.
Any advise will be really apreciated.
