  3. Layout XL: How can I create different pins for an electrically...
  • Subscribers 129
  • Views 5718
Layout XL: How can I create different pins for an electrically connected layout?
mehmetcanbcn
mehmetcanbcn over 2 years ago
I have created a custom resistor in Layout XL. I am trying to add different pins for the input and the output of this resistor, but when I add a pin to the resistor, the pin information propagates through the resistor to the output. How can I add different pins to this electrically connected layout?
Kind regards.
  • mehmetcanbcn
    I have "solved" the issue. I just added the input and the output pins as needed and ignored the short warnings in the 'Annotation Browser' tab. After this I assigned layout instance terminals to nets by using the 'Define Device Correspondence' menu.
  • RobMan
    RobMan over 2 years ago
    Which PDK are you using? The techfile needs to support a definition layer for the resistor which "breaks" he connection through the metal layer.
