  3. PAC simulation issue, "No valid time points are specified...
  • Subscribers 129
  • Views 1688
PAC simulation issue, "No valid time points are specified"
FV031
FV031 over 2 years ago
Having Issues running PAC. It ran in the first iteration and then when I changed some input parameters It started to fail.
I checked the PSS waveform and it does cross the threshold.
Command line:
/home/tools/cadence/SPECTRE211.460/tools/bin/spectre -64 input.scs +escchars +log ../psf/spectre.out -format fsdb -raw ../psf +preset=mx +mt=4 +lqtimeout 900 -maxw 5 -maxn 5 +lorder \
MMSIM:PRODUCT -env ade -ahdllibdir /*/maestro/results/maestro/Interactive.7/sharedData/Job149/ahdl/input.ahdlSimDB +logstatus
"Error found by spectre during PAC analysis `pac'.
ERROR (SPCRTRF-15168): No valid time points are specified for the sampled analysis `pac'. The analysis is skipped.
To fix the problem, please verify that: 1) Threshold value is within the range of probed signal. 2) Additional timepoints are specified less than the fundamental period.
Analysis `pac' was terminated prematurely due to an error."
  • FV031
    From the netlist:
  • FV031
    It runs with Spectre and with SpectreX it seems to be hit or miss!
    Andrew Beckett over 2 years ago in reply to FV031
    Please contact customer support (submit a case after logging in). It's pretty likely to be some specific circuit-dependent issue. I can't think of a general reason why this would fail (sometimes) with Spectre X.
