  3. scaling and DBU/UU - XStream vs XOasis
  • Subscribers 129
  • Views 1555
vshih
vshih over 2 years ago
Virtuoso 6.1.8-64b
    techfile: dbuperuu:    1,000
During stream out, I would like to create higher resolution (DBU/UU = 10,000), while changing scale to be 0.9.
Question:
1. What would be the issue/concern, if I did this translation (Virtuoso DBU/UU = 1000, then gds/oasis DBU/UU = 10,000)?
2. I could do above process using XStream, in which there is option for me to change DBU/UU and scale factor in the same translation.
    However, I don't see the same option from XOasis, which only offer DBU/UU option but NOT scale option.
    Any suggestion? I want the output file to be oasis than gds.
    XStream and XOasis is from CIW -> File -> Export
    As far as I can see, oasis out doesn't provide a -scale option (but strmout does) - just a -dbuPerUU. I suggest you contact customer support. Using higher resolution isn't an issue with either format as you're not losing resolution.
