  3. Using extracted view with iterated instance
  • Subscribers 129
  • Views 5748
Mathieu Chene
Mathieu Chene over 2 years ago
I am working on a design of SRAM and I am trying to validate it with an array composed of 4 words of 8 bits.
I designed a bit  cell which has been instanciated 8 times in another cellview to create a word:
and then I use an iterated instance of my word cellview in my test bench:
I'm using the AMS simulator with ADE explorer to validate my design and everything works as expected when I use the schematic view. All the words are initialised when the word lines are high.
However, when I use an extracted view (defined with the config view of my cellview testbench) of my layout, it seems that the stored values of 2 different instances are connected.
(here is and exemple with the bits 6 and 0 from instance 1 and 0 that are suposed to be initialized differently)
Here is a screenshot from my view config:
When I do this simulation using 4 different instances of my word cell , I have the same behavior than in schematic based simulation (with expected variation due to the parasitics):
(here Q1<0> and Q1<6> are initialized after ~20ns and I do not use any initial conditions, this explain the behavior just before 20ns)
I admit that I am stuck with this problem, do you have any idea on the reason of this behavior
Thanks in advance
Mathieu
    Mathieu,
    I would advise you to contact customer support about this - it will be much easier to debug with a screen-sharing session.
  • Mathieu Chene
    Mathieu Chene over 2 years ago in reply to Andrew Beckett
    ok Thank you
