  3. Creating vector variable in ADE XL to configure Verilog...
  • Subscribers 129
  • Views 5508
Creating vector variable in ADE XL to configure Verilog-A module
RaffaeleUdS
RaffaeleUdS over 2 years ago
I would like to send a vector through the ADE XL variable sets to a Verilog-A module.
I have a parameter set in the Verilog-A as:
electrical     [3:0]    B_RCH;
parameter integer RCH_b[3:0] = {0,0,0,1};
And each bit configures an output bus of the module like so:
generate j (3,0) begin
V(B_RCH[j]) <+ (RCH_b[j])*V(VDD);
end
Now, I can set the parameters successfully in ADE L "Design Variables" setting:
RCH_b |  [1,0,1,0]
Nevertheless, if I try the same in ADE XL this doesn't work.
How can I achieve this?
Also, is it possible to run different simulations varying the vector with a CSV file?
    See How to convert design variables which are spectre vectors to work with Explorer/Assembler
    I think you might just need to make the variable value strcat("[1 0 1 0]") in ADE XL instead.
    Not really a way to vary the vector with a CSV file (since you can't do that in general with ADE XL), but you could define a CSV file for a set of corners each with a different value of the vector (with the strcat() around it) and then import that into the corners tool. Note I have not tested this so it might not work - but I think it probably should if done correctly.
    BTW, you should be using Assembler rather than ADE XL since ADE XL is obsolete.
