  3. Load pull contour plot error
  • Subscribers 129
  • Views 5018
Martinsh
Martinsh over 2 years ago
Dear Sir,
Run Load pull simulation:
1) HB simulation with sweeping input power (Pin)
2) Setup portAdaptor with Mag and Phase sweep
After simulatoin, saturated power is got with equation:
Psat = value(Pout lastVal(Pout))
So, Psat is a two dementional parameter and it relates to the Mag and Phase of load impedance.
But when I plot a contour with following function, error is reported.
awvRfLoadPull(Psat ?maxValue nil ?minValue nil ?numCont 8 ?closeCont t)
It says,
*Error* awvRfLoadPull can handle two or three dimension sweep results only
ERROR (VIVA-3002):expression evaluation failed: Expression evaluates to nil
ERROR (VIVA-3002):expression evaluation failed: awvRfLoadPull(Psat ?maxValue nil ?minValue nil ?numCont 8 ?closeCont t)
If I plot Psat directly, it's OK. What's wrong with this contour plot method?
Martin
