  3. Updating Run Plans
  • Subscribers 129
  • Views 5336
Updating Run Plans
TempViator
TempViator over 2 years ago
Hi.  I have created a very long set of Run Plans, but decided I needed to add a new test to all of them.  That new test is currently in my active setup test list.
Is there a way to update all my Run Plan runs at once to see my new list of tests, rather than having to create a new Run Plan from Active setup, and then manually rebuild all my existing Run Plans?
I see that Run Plans can live update to existing changes in the Active Setup, but this is "adding to" not "modifying".
Thanks!
  • TempViator
    Forgot to mention that my tool version is IC6.18.180.
    Andrew Beckett over 2 years ago in reply to TempViator
    I think you probably have to just drag the new test over to each run in the run plan (you could either drag the root of the Tests or the individual test). I'm not sure there's an easy way to update all the tests in one go (you certainly don't need to recreate them) - it's a good question though, so I suggest you contact customer support (sorry, don't have the bandwidth at the moment to properly check this out myself).
