  3. Ocean Post Processing on a sweep
  • Subscribers 129
  • Views 5193
david73
david73 over 1 year ago
I want to run a simulation on multiple points, and then have an ocean post processing script run on all the results together. I am reasonably proficient in ocean, and I can dump results to a file, and have a python script run the analysis. I want to have the results displayed in the sweep section, like the picture, but my question is whether a script run in this form will be able to access shared variables from the sweep. (let's say I have a variable called Corner_Num, and that obviously doesn't change during the sweep)
    Yes, your OCEAN script should be able to access VAR("Corner_Num") (I assume by "variable" you mean an ADE variable).
