  3. Equation Syntax
  • Subscribers 129
  • Views 5250
Equation Syntax
Maria98
Maria98 over 1 year ago
Hi
I want to find out the Quality Factor, Inductance, and resistance of the designed inductor layout through its s2p file.
The basic equation to calculate the above values is:
zdiff=Z(1,1)-Z(1,2)-Z(2,1)+Z(2,2)
i wrote in ADE L calculator as:
(db(zpm('sp 1 1)))-(db(zpm('sp 1 2)))-(db(zpm('sp 2 1)))+(db(zpm('sp 2 2)))
with name zdiff.
but its waveform is not appearing.
Please guide
Thank you
    I'm not sure why you would want to add/subtract the z-parameters in dB - that seems wrong to me. I'd have expected you really wanted to do:
    zpm('sp 1 1 )-zpm('sp 1 2 )-zpm('sp 2 1 )+zpm('sp 2 2 )
    However, if you really did want to add the values in dB, then you have too many parentheses. SKILL (and hence the ADE calculator) is fussy about having too many parentheses - it confuses the parser. You had an additional set around every db() call, so if you use this:
    db(zpm('sp 1 1))-db(zpm('sp 1 2))-db(zpm('sp 2 1))+db(zpm('sp 2 2))
    it should work correctly (whether the results are what you want or not is another matter).
  • Maria98
    Maria98 over 1 year ago in reply to Andrew Beckett
    Thanks a lot, i was doing mistake by adding dB values.
