  3. How do Maestro and caculator average the waveform of a digital...
  • Subscribers 129
  • Views 5272
How do Maestro and caculator average the waveform of a digital signal
wangyunxin
wangyunxin over 1 year ago
For example, binary_out<7:0> in the figure is a digital signal whose hexadecimal value is 3c and the corresponding decimal value is 60. Now I want to directly average binary_out from half of the simulation time to the end of the simulation time, and the result should be 60. So I used the following code, but it didn't work
average(clip(VT("/binary_out<7:0>") (VAR("STOPTIME") * 0.5) VAR("STOPTIME")))
What should be the correct operation?
  • wangyunxin
    ok,this code “average(clip(VT("/binary_out<7:0>") (VAR("STOPTIME") * 0.5) VAR("STOPTIME")))” work,I made some small mistakes
