  3. How do I change the name and unit of the X-axis in “plot...
  • Subscribers 129
  • Views 6338
How do I change the name and unit of the X-axis in “plot across design points”
wangyunxin
wangyunxin over 1 year ago
In maestro, I scanned different voltage values to see the change of a certain parameter. For example, in the figure above, I scanned VOUT from 0.6V with a step size of 0.01V to 1V.Then I used "plot across design points" to see the situation of this parameter under each voltage.
However, the unit of the X-axis shown in the waveform diagram is not voltage but "design point".How to solve this situation?
    If you don't want it plotted against the design point, then don't use "plot across design points"!
    If you use "Plot All" instead, it may well plot with the x-axis being your swept variable. It might not though if you are sweeping more than one thing (e.g. corners or another variable) but you can always use the right mouse button menu over the x-axis to change the swept axis, or alternatively send to the calculator and use the swapSweep function. If you want such a swapSweep output to appear in your ADE outputs, you can generate the expression and add it as an output with the EvalType column set to "sweep" (in Explorer this column doesn't show by default; you have to go to the column headers in the Outputs Setup and right mouse button to enable it).
