  3. Set the sequence of multiple tests (ADE Assembler)
  • Subscribers 130
  • Views 5339
NeoTED
NeoTED over 1 year ago
Hi:
I am validating a circuit with 4 loops, so I created an Assembler with 5 tests (Test0, Test1, Test2...).
Test0: run transient for several μs until the circuit reaching a desired operation point.
Test1: run stb to evaluate the stablility of loop1, based on the operation point generated by Test0.
other Tests also read the op file generated by Test0.
However, Test0 and other Tests start simultaneously. So the op file is not ready, when stb runs.
I want to know how to set the sequence of multiple tests.
Thank you!
  • Frank Wiedmann
    Frank Wiedmann over 1 year ago
    Use a (dummy) calcVal() expression referencing Test0 in the other tests.
