  3. Assembler evaluating disabled outputs
  • Subscribers 129
  • Views 4653
AncisMichele
AncisMichele over 1 year ago
according to my "flow", I tend to have tests in Assembler with associated multiple analyses.
I often do not want/need to have all analyses in a test to be run. For instance, I might be exploring in more detail some DC conditions and only need the corresponding analysis, while I want to leave out some HB or NOISE.
I also have outputs set for plotting and of course these can be relative to any of the analyses in the test. I then switch off those outputs relative to analyses I am not currently running, in order to avoid that "eval err" notification in the results pane.
However, I noticed that, no matter what I do, the CIW keeps complaining about a bunch of  errors about results that can't be computed. This, despite their relative output being ticked off.
I find this both confusing and annoying and I would like to understand whether this is the result of some misuse I am doing of the tool, or perhaps there's a configuration that can be changed in order to avoid Assembler trying to evaluate something which has been explicitly switched off.
Lately I am grouping my outputs in OCEAN files, so that I can switch on/off outputs as groups instead of ticking them off one by one.
Still, the outcome is the same: Assembler keeps trying to evaluate the OCEAN script(s), and gives an ERROR because the elements defined there are not available.
I'm running ICADVM20.1-64b.500.300
Any suggestions?
Thanks!
Michele
    Michele,
    Please contact customer support - something sounds wrong here.
