  3. Is there a Calculator function like firstVal to get the...
  • Subscribers 129
  • Views 6169
Is there a Calculator function like firstVal to get the y-value
Volker T
Volker T over 1 year ago
Dear all,
Calculator function firstVal() returns the first x-value of a waveform.
I wonder, if there is something like firstVal() to return the first y-value.
Example:
Imagine a DC voltage sweep from 1 V to 2 V and a resulting output waveform VS("/result") with some arbitrary data.
firstVal(VS("/result"))
returns 1.0, as my voltage sweep starts at 1.0 V.
Of course, I could find the corresponding "first" y-value with
value(VS("/result") firstVal(VS("/result")))
The point is though, I need this in a way more complex function, and the formula gets very complex and hard to read if there was no simple and compact way, like a hypthetical "firstY()" function to do the job, like this:
firstY(VS("/result"))
Obviously, ymin or ymax cannot do the job, as the data is arbitrary, i.e. not in ascending or descending order.
    See this article: How can I get the first or last X or Y value from a waveform?
    It doesn't have the functions to register it with the calculator (only the old way of doing it - I'll aim to update the article in the next day or so) - but using the fx button should add the relevant code to the file for you.
    Andrew Beckett over 1 year ago in reply to Andrew Beckett
    The article is now updated to have the the builder template stuff included rather than the historical way of registering a calculator function.
  • Volker T
    Volker T over 1 year ago in reply to Andrew Beckett
    Thank you very much.
    In the mean time, I had my own Calculator functions "firstY" and "lastY" implemented, working exctly the same way. Still, it is very helpful to see your code.
    Edit:
    I also added a conditional
            (numberp(signal)
                signal
    so that the function can also handle a simple scalar value (you use "wave" as argument name, not "signal" as I do).
