  3. Virtuoso ADE Assembler - expression evaluation error: *Error...
  • Subscribers 129
  • Views 5028
Virtuoso ADE Assembler - expression evaluation error: *Error* eval: undefined function - ciwMenuInit
dr3patel
dr3patel over 1 year ago
Tool: Cadence Virtuoso ICADVM20.1-64b.500.27,  ADE Assembler - Maestro
My single-point DC simulations work fine and all the expressions (i.e. OP("/P0" "gm") etc.) work fine. However, when I try to do the variable sweep DC simulation, I get the "eval error" for the expression evaluation of Operating point sweep (OS) parameters. I checked the 'Expression Evaluation Log' by right-clicking the 'eval err' > 'view log messages' and it shows " *Error* eval: undefined function - ciwMenuInit" (see attached screenshot below)
My expression consists of the following OP parameters:
OS("/P0" "gm")
OS("/P0" "vth")
OS("/P0" "gds")
OS("/P0" "cds")
etc.
All the DC sweep simulations finish fine without any simulation errors as monitored through the simulation log window (also shown in the attached screen shown above).
I noticed very unsual behavior as follows: When I click on the red colored 'eval err' of any expression such as OS("/P0" "gm"), it will in fact show the correct results in a plot. I confirmed this from the result browser. So, I believe, the expression was evaluated but somehow still labels it as 'eval err'.
Another weird thing I noticed is that when I include the DC variable sweep simulations, it also shows 'eval err' for all the other expressions NOT associated with DC sweep as well. For example, having as simple as (2+2) shows up with 'eval err'. However, when I remove the DC sweep simulation and their associated expressions, the rest of the expressions work fine (i.e. (2+2) would print 4.
Let me know how to overcome this weird error. thanks!
Dhruv Patel
    Dhruv,
    The ciwMenuInit() is a red herring I believe, as for me having that in my .vdsinit gives the error in the expression log but does not trigger an eval err. It's probably caused by having your .vdsinit and .cdsinit either linked together or one loading the other, which is not the intended usage - however, I don't think that's your problem.
    I can't reproduce the problem with ISR27, even if I turn off saving of the oppoint outputs (if I do that, I only get eval error on the OS() outputs).
    I would suggest you contact customer support (submit a case after logging in).
  • dr3patel
    dr3patel over 1 year ago in reply to Andrew Beckett
    hmm. Ok - will submit the case through customer support. Thanks, Andrew.
    Dhruv
  • dr3patel
    I had a quick meeting with the Cadence support and they were able to solve this issue by making me append the following line in my .cdsinit file.
    envSetVal("maestro.exprEval" "binaryName" 'string "virtuoso")
    This solved my expression evaluation issue.
    Thanks!
    Dhruv
    Andrew Beckett over 1 year ago in reply to dr3patel
    Dhruv,
    I'm not convinced that's a desirable solution - since the whole point of the expression evaluation being done via "vds" rather than "virtuoso" is that it's more lightweight to start than virtuoso. It's a workaround, sure, but not sure it's the best approach. You might want to find out from the AE if this recommendation is to workaround a known issue, or if there's some other reason why the default "vds" won't work in your case.
