  3. Optimize and speed up automatic routing
  • Subscribers 129
  • Views 4761
RuihW
RuihW over 1 year ago
Hello everyone,
I'm using automatic route to create connections between two blocks that are placed vertically. There are about 80k nets to be routed.
The automatic route has been running for a week and the log window freezes like this:
For the layout, every instance inside block A has a pin on Metal 1 for routing. However, the pin is tightly surrounded by metal 1 to metal 3. So the only way out is to add vias and start routing on metal 4.
Block B has lots of rooms so the routing can start from metal 2.
I'm looking for a way to speed up the routing. The auto route stuck at cycle 1 for a week doesn't look right to me.
How do I make the auto route aware that it's supposed to route from metal 4 in block A? Should I add vias to the instance and place the pin on Metal 4 as well?
Thanks!
