  3. Different number of ports in NPORT and S-parameter file
  • Subscribers 129
  • Views 5075
Aldo3
Aldo3 over 1 year ago
is it possible to set as an ERROR (stopping the netlist) the WARNING we have when the number of ports in NPORT and in the S-parameter file are different?
WARNING (CMI-2131): 12 port data file `/home/.../touchstone_s12p/text.txt' used as 8 port.
Thank you
Best regards
Aldo
  • JankoK
    JankoK over 1 year ago
    Hi Aldo,
    You should be able to change the severity of warnings to errors...
    Here is an example: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000007MdAEUA0&pageName=ArticleContent
    It is a different warning but the procedure should be the same. Please try it out and let me know.
    BR
    /Janko
  • JankoK
    JankoK over 1 year ago in reply to JankoK
    Yup, it works as described in the article with:
    warning_change_severity=error warning_id=[CMI-2131]
    In ADE, you should add this in the Simulator Options form (Simulation - Options - Analog) under the Miscellaneous tab in the Additional Arguments field.
    /Janko
  • Aldo3
    Aldo3 over 1 year ago in reply to JankoK
    Many thanks Janko, it works.
    Best regards
    Aldo
