  3. Change setup of the extracted netlist (Calibre view) --...
  • Subscribers 129
  • Views 732
Change setup of the extracted netlist (Calibre view) -- extraction with QRC
BitanMallik
BitanMallik over 1 year ago
I have generated an extracted netlist (Calibre view) for a circuit.
And, I see each device (e.g. MN1) is represented via MMN1, MMN1@2, MMN1@3 ... in the extracted netlist (separated into fingers).
Is it possible to retain the same device name and same number of instances within the extracted netlist?! Maybe I am missing something in the flow.
Note: I am using Calibre for extraction.
Thanks!
