  3. Spice sub-circuit in the schematic editor
  • Subscribers 129
  • Views 4979
Bakr Abdelgaliel
Bakr Abdelgaliel over 1 year ago
I need to use a spice sub-circuit from LTspice in the Virtuoso schematic editor.
I copied and pasted the .subckt attached to a Spice text editor file. However, it gives me the following errors:
Error: Instance `B1': Unexpected value `uplim' - this element does not accept any positional parameters.
Error: Instance `B1': Unexpected value `v(1)' - this element does not accept any positional parameters.
Error: Instance `B1': Unexpected value `v(3)' - this element does not accept any positional parameters.
Error: Instance `B1': Unexpected value `0.2' - this element does not accept any positional parameters.
Error: Instance `B1': Unexpected value `0.1' - this element does not accept any positional parameters.
Error: Instance `B1': Unexpected value `v(4)' - this element does not accept any positional parameters.
Error: Instance `B1': Unexpected value `-0.2' - this element does not accept any positional parameters.
Error: Instance `B1': Unexpected value `+1n*V' - this element does not accept any positional parameters.
Error: Instance `B1': Unexpected value `1' - this element does not accept any positional parameters.
Error: Instance `B1': Unexpected value `-1.4705e-10' - this element does not accept any positional parameters.
Error: Instance `B2': Unexpected value `uplim' - this element does not accept any positional parameters.
Error: Instance `B2': Unexpected value `v(2)' - this element does not accept any positional parameters.
Error: Instance `B2': Unexpected value `v(3)' - this element does not accept any positional parameters.
Error: Instance `B2': Unexpected value `0.21' - this element does not accept any positional parameters.
Error: Instance `B2': Unexpected value `0.1' - this element does not accept any positional parameters.
Error: Instance `B2': Unexpected value `v(4)' - this element does not accept any positional parameters.
Error: Instance `B2': Unexpected value `-0.21' - this element does not accept any positional parameters.
Error: Instance `B2': Unexpected value `+1n*V' - this element does not accept any positional parameters.
Error: Instance `B2': Unexpected value `2' - this element does not accept any positional parameters.
simulator lang=spice
.subckt LTC6082 1 2 3 4 5
X1 2 1 0 0 0 0 0 0 OTA g=0 in=.5f
B1 0 N004 I=10u*dnlim(uplim(V(1),V(3)+.2,.1), V(4)-.2, .1)+1n*V(1)-147.05p
B2 N004 0 I=10u*dnlim(uplim(V(2),V(3)+.21,.1), V(4)-.21, .1)+1n*V(2)
C10 N004 0 50f Rpar=100K noiseless
M1 5 N011 4 4 NI temp=27
C2 3 5 1p Rpar=100Meg noiseless
D5 N011 4 DLIMN
M2 5 N007 3 3 PI temp=27
D8 3 N007 DLIMP
C3 3 N007 10f Rser=1.5Meg noiseless
X3 N008 N009 4 4 4 4 N007 4 OTA g=200n ref=-37m linear vlow=-1e308 vhigh=1e308
C11 5 4 1p Rpar=100Meg noiseless
C12 N011 4 10f Rser=1Meg noiseless
X4 0 N004 0 0 0 0 N005 0 OTA g=1u linear en=12.6n enk=55.4 Vhigh=1e308 Vlow=-1e308
C16 N009 5 790f
X5 N006 0 N008 N008 N008 N008 N009 N008 OTA g=18u iout=1.4u Vhigh=1e308 Vlow=-1e308
G1 4 N011 N009 N008 200n
D9 N009 N008 DLIM
C7 3 1 3.5p Rser=10 Rpar=5T noiseless
C13 3 4 1000p
C1 N005 0 105f Rpar=1Meg noiseless
G2 0 N008 4 0 .5m
G4 0 N008 3 0 .5m
C18 N008 0 200p Rpar=1K noiseless
D1 2 1 DIN
G3 0 N006 N005 0 1m
L1 N006 0 170µ Cpar=177f Rser=1.07k Rpar=15.28k noiseless
C9 N007 5 50f Rser=1.5Meg noiseless
C8 5 N011 50f Rser=1.5Meg noiseless
C4 3 2 3.5p Rser=10 Rpar=5T noiseless
C5 1 4 3.5p Rser=10 Rpar=5T noiseless
C6 2 4 3.5p Rser=10 Rpar=5T noiseless
D3 3 2 DBIAS
D4 3 1 DBIAS
D6 2 3 DESD
D7 4 2 DESD
D10 1 3 DESD
D11 4 1 DESD
D2 3 4 DPOW
.model DIN D(Ron=1k Roff=10T Vfwd=1.5 epsilon=.1 Vrev=1.5 revepsilon=.1 noiseless)
.model DBIAS D(Ron=1g Roff=1T epsilon=.3 ilimit=.2p noiseless)
.model DPOW D(Ron=1k Roff=1G Vfwd=.1 epsilon=50m ilimit=252.8u noiseless)
.model NI VDMOS(Vto=300m kp=30m lambda=.01)
.model PI VDMOS(Vto=-300m Kp=30m lambda=.01 pchan)
.model DLIM D(Ron=100k Roff=70Meg Vfwd=200m Vrev=200m epsilon=10m revepsilon=10m noiseless)
.model DESD D(Ron=10 Roff=10T Vfwd=.7 epsilon=.1 noiseless)
.model DLIMN D(Ron=100k Roff=100Meg Vfwd=1.65 Vrev=-300m epsilon=.1 noiseless)
.model DLIMP D(Ron=100k Roff=100Meg Vfwd=1.55 Vrev=-300m epsilon=10m revepsilon=10m noiseless)
.ends LTC6082
    Spectre does not support LTSPICE models. The closest is probably PSPICE models, but putting the subckt above in a pspice view generates a bunch of errors because it's not pspice syntax. (Spectre does support Pspice models, but you should use the Pspice view type for this).
