  3. VSR not dropping vias to short all pins
  • Subscribers 129
  • Views 5366
MARTH0401
MARTH0401 over 1 year ago
I have multiple horizontal m2 layers (one on top of the other that have the same terminal and net name). The only diffrence is the pin names are different. VSR only connects only one pin at the top level after the run finishes. The expectation is that m3 would be extened from top to bottom of each horizontal m2 layer and a v2 is placed on each horizontal layer. Instead VSR only drops one v2 and call it quits. Why will VSR not connect all the pins together here?
  • MARTH0401
    This is what I am trying to explain in the description above. Why is VSR not wanting to extend M3 all the way to the top and drop via2 for the remaining three pins? a_1,a_2,a_3,a_4 all share terminal and net name "a".
    I already tried "must connect all pins" and "must connect" features in pin connectivity settings and VSR did not do anything different. I assigned pin "a" as must connect all pins and also try must connect. Is something still preventing the VSR router from not recognizing the pins?
    I have also tried setting the following variable in the .tcl file because I need to connect more than one instance in the layout and currently the router is only connecting one single pin.
    setvar db.connect_IO_pin_shapes true
  • RobMan
    RobMan over 1 year ago in reply to MARTH0401
    The model you describe should work. What does the form 'Connectivity -> Pins -> Pin Connectivity Setting' show?
  • MARTH0401
    MARTH0401 over 1 year ago in reply to RobMan
    It shows the following structure
    -Ungrouped Terminals
          - a [(must connect all pins | symbolic_default | signal)]
                   - a_1
                       a_1
                   - a_2
                       a_2
    and so forth..
  • MARTH0401
    MARTH0401 over 1 year ago in reply to MARTH0401
    Any feedback on this? Its been a few days
  • RobMan
    Apologies. I missed your update. The 'mustConnect' model looks correct. I suggest you contact customer support.
    Rob.
