  3. Maestro - design variables form fetching deleted variab...
  • Subscribers 129
  • Views 1056
Maestro - design variables form fetching deleted variables
firebolt3
firebolt3 over 1 year ago
I'm not sure how & why design variables is still fetching old variables which are deleted & replaced with values. Simulation will run fine but, when I click 'copy from cellview', old variables show up. This is happening even with new Maestro. Is there any form in schematic which has this data?
virtuoso version ICADVM20.1-64b.500.34
    When you do Copy From CellView it does two things:
    1. Get the designVarList on the test bench cell (not cellView)
    2. Search the hierarchy for any design variables used in the design hierarchy (won't have a value in those cases though).
    You can check the properties in the library manager by using Right Mouse→Properties over the cell not cellView). You can see the properties here:
    You can delete this property (or edit it) to remove the defaults coming from here.
