  3. Modifying the ADE Assembler "Open MATLAB" command
  • Subscribers 129
  • Views 1632
Ricardo1
Ricardo1 over 1 year ago
Hello
Currently, when I click on "Open MATLAB" via the ADE Assembler, another matlab version is opened (an older version that doesn't support Mixed-Signal Analyzer).
I can fix this if I had a way to modify the command that Cadence executes to launch a newer matlab version (I just need to point to the correct MATLAB version that I have).
I suspect "Open MATLAB" simply executes "matlab" through a terminal... but I have a separate command that launches a more modern version
thanks in advance
    The mechanism is finds "matlab" from your path rather than giving another configuration mechanism. Since this is the standard way of finding executables, why not fix your $PATH to ensure that the correct version is found first? Or add a wrapper (if you can't change the path, which seems a bit odd) called "matlab" which exists earlier in the path that executes the one you want?
    It would seem unnecessarily complicated to add a way to change the command that is launched (we actually run axlMatlab which sets up a few things and then runs the actual matlab from $PATH).
  • Ricardo1
    Ricardo1 over 1 year ago in reply to Andrew Beckett
    Thank you Andrew, the short answer to your question is that the system path for "matlab" is fixed to an older version of MATLAB (there are other users in the same server that require it). If I launch system("matlab") through CIW, it indeed opens up the older version.
    This usually isn't an issue since I can type a separate command on terminal that points to another path. I currently alias "matlab" to the command for the newer matlab, but unfortunately it seems like ADE doesn't see this.
    Is it at all possible to somehow change environment in .cdsinit or something?
    Andrew Beckett over 1 year ago in reply to Ricardo1
    You could add:
    setShellEnvVar("PATH" strcat("/path/to/directory/for/newer/matlab:" getShellEnvVar("PATH"))
    in your .cdsinit. This means that when "matlab" is launched from Virtuoso, it will look first in the additional directory that you've prefixed onto $PATH.
