  3. ViVA- set different color to each psf
  • Subscribers 129
  • Views 959
firebolt3
firebolt3 over 1 year ago
Is there a way to set only one color to all waveforms under single psf? This will help when comparing 2 psf data, say different corners/testcases. Right now, I'm changing color manually by selecting required waveforms.
virtuoso version ICADVM20.1-64b.500.34
  • firebolt3
    Any help here?
    Andrew Beckett over 1 year ago in reply to firebolt3
    firebolt3 said:
    Any help here?
    First of all, if this is urgent enough that you need to chase this, you should contact customer support. These pages are a community forum where people answer in their spare time.
    I looked at this at an airport yesterday, and couldn't find a way to do this other than manual selection of the traces and editing them all at once. The closest would be the "Customize Trace Groups" assistant, but this doesn't (yet) have a "database" choice - so I filed an enhancement request - CCR 2983744. You might want to contact customer support and ask for a duplicate to be filed on your behalf so that it is associated with an actual customer rather than being an internal suggestion.
