  3. create single wire context sensitive menu
  • Subscribers 129
  • Views 4102
punya
punya over 1 year ago
I do not get create single wire context sensitive menu, after right clicking on wire. could please tell me how to enable this option
    I don't understand what you mean. If you're talking about the context sensitive menu when over a single wire in the schematic, there should be nothing to enable. In current versions (e.g. latest IC6.1.8 ISR) you get:
    This just works. If not, please explain which tool you're using, which IC sub-version you are using, and share some screenshots of exactly what happens (or doesn't happen) for you.
