  3. Meaning of 1v in pmos_1v in gpdk045 library
  • Subscribers 129
  • Views 5070
APM
APM over 1 year ago
What is the meaning of1v in pmos_1v in gpdk045 library?Does it signify the threshold voltage or does it mean the maximum supply voltage that the instance can withstand.
  • APM
    APM over 1 year ago
    What is the meaning of 1v in pmos instance in gpdk045 library?Does it signify threshold voltage or maximum supply that can be given?
    First of all, as per the Forum Guidelines, please do not post the same question in more than one forum (I combined your two into the same thread).
    This is covered in the documentation for gpdk045. It's in the docs folder, in a file called gpdk045_pdk_referenceManual.pdf on page 18 in the v6.0 of the PDK. This lists the supported devices and their purpose.
  • APM
    APM over 1 year ago in reply to Andrew Beckett
    Got it.Thank you.
