  3. *Error* eval: undefined function - mgc_calibre_run_drc
  • Subscribers 129
  • Views 1300
Saumeek
Saumeek over 1 year ago
We tried to run drc for our layout of buffer schematic using Cadence Virtuoso IC23.1-64b.ISR6.30. But it gives this error
  • Saumeek
    Also, following is the error while trying to run nmLVS of the same layout
    *Error* eval: undefined function - mgc_calibre_run_lvs
    Andrew Beckett over 1 year ago in reply to Saumeek
    Note that your issue is with running Calibre which is not a Cadence tool. It suggests that you do not have the Calibre interface properly loaded, and you would probably be better asking a question to either Siemens EDA support or on a Siemens EDA forum (since it is their tool and their interface).
