  3. maestro Results pane order. "Undo Sorting" gray out
  • Subscribers 129
  • Views 1866
hdngo
hdngo over 1 year ago
Why is my "Undo Sorting" button is gray out? Thanks
    It will be greyed out if you didn't sort any columns, plus there was a bug in IC23.1 which was fixed in IC23.1 ISR5 (subversion will be of the form IC23.1-64b.ISR5.xx). Which IC subversion are you using (Help->About will tell you this)?
  • hdngo
    hdngo over 1 year ago in reply to Andrew Beckett
    Thanks Andrew! I did sort the column by accident. I am using version IC23.1-64B.43.
    Why do we have this function in the first place? I don't see any benefit of locking it up if the user accidently sorting the output. Thanks again!
    Andrew Beckett over 1 year ago in reply to hdngo
    Ok, so you’re using the a broken version. The intention of this button is that it will restore the default order if you’ve sorted one of the columns, but a change in IC23.1 resulted in the button always being greyed out which was clearly a bug. That has been fixed but you’ll need to use a later hotfix version to get the fix - as I mentioned before.
  • hdngo
    Thanks Andrew!
  • hdngo
    New version fix it. Thanks!
