  3. Conversion Gain using HB analysis
  • Subscribers 129
  • Views 4182
Maria98
Maria98 over 1 year ago
hi, i am trying to simulate the conversion gain of the upconverter double balanced mixer, taking an example from one paper (schematic below). I did not understand the setting of the two tone analysis to get a 1 GHz input harmonic for the input IF port and a 60 GHz output harmonic for the modulated output port ( to get the power gain curve). Please guide for two tone setting. Thanks
(Paper title: A 60-GHz Double-Balanced Mixer for Direct Up-Conversion Transmitter on 130-nm CMOS)
  • JankoK
    JankoK over 1 year ago
    Hi Maria,
    You can find the instructions here:
    Simulating Mixers
    You will need to scroll down a bit to get to the two-tone part...
    By the way, you can also find this mixer from the user guide under your Spectre installation:
    <SPECTRE>/tools.lnx86/spectre/examples/SpectreRF_workshop
    You can then copy the tarball to you work area, un-tar it and play... The mixer is here:
    Lib WorkshopLib, Cell db_mixer
    Some things are already pre-set in maestro_ref, but I think those are some noise tests. You will have to build two-tone tests yourself by following the guide.
    Good luck!
    /Janko
