  3. Maestro - get instant value of net for delay measuremen...
  • Subscribers 129
  • Views 842
Maestro - get instant value of net for delay measurement
firebolt3
firebolt3 over 1 year ago
I have vdd ramping up & clkout follows the same vdd. But when measuring delay, threshold should be instant value of vdd / 2 rather than fixed vdd from variable. How to get this instant_vdd value for threshold entry? Attached picture shows plots & required expression format. Thanks.
    The threshold can't currently vary, but this is easily solvable by reformulating it slightly.
    Change:
    • Signal1: VT("/clk_out")-VT("/vdd")/2
    • Signal2: VT("/clk_out")-VT("/vdd")/2
    • Threshold Value 1: 0
    • Threshold Value 2: 0
    By subtracting half the supply voltage from the input signal, your threshold now is a fixed 0 value at all times - you've just "normalised" it to half the supply voltage.
  • firebolt3
    firebolt3 over 1 year ago in reply to Andrew Beckett
    Excellet Andrew. Thanks a lot. Slight smile
