  3. DRC rule deck writing
  • Replies 17
  • Subscribers 136
  • Views 12301
thiruvenkata
thiruvenkata over 1 year ago
Hello all, I am a beginner in writing DRC rule deck,
I need to check spacing between single or two different layers, I can use exte keyword to raise error but exte keyword has some restrictions, Now I need to check spacing between the two shapes and raise error, but the problem the spacing should be exact in my case, I can raise error if the value is less than specified constraint but I cannot raise error if the spacing is greater than specified constraint.
  • RobMan
    RobMan over 1 year ago in reply to thiruvenkata +1
    Hi Thiruvenkata, But that is what you asked for: " I can raise error if the value is less than specified constraint but I cannot raise error if the spacing is greater than specified constraint". i.e…
  • RobMan
    Yes, so you have two shapes: The space between the two shape is exactly 2.0. However, every other edge is not exactly 2.0 from another shape. So they WILL flag... The top, left and bottom of the left…
  • RobMan
    OK. But you do understand that in picture 1 the outside edges are indeed not exactly 2 from another shape. So let's consider a real design: 1) How many shapes of the relevant layers are you expecting…
  • thiruvenkata
    thiruvenkata over 1 year ago in reply to RobMan
    Hi, Robman, How can I highlight the edges without error name, similar to the edges what you flagged here in the first picture case.
    How can I hide error name? and only highlight error region.
    Edit: I found it. Tools->preferences->show error checkbox
    Is there any way to make error marker line thicker?
  • RobMan
    Sorry, I don't fully understand this question: The code I suggested will result in picture 1.
    exte layer1 layer 2 -eq 2.0 -output negative1;
  • thiruvenkata
    Sorry for that, I wanted to customize the error markings, the error marking region in your picture 1 and error marking in my picture 1 is different right?
    I don't want the error name 'edge' in my error highlighting, I found necessary option to disable it.
    Now I want a solution to make my error marking lines thicker, is there any way to do it?
  • RobMan
    The error is an 'edge' object: Output this as a temporary layer and use 'edge_expand' to derive a new error marker object.
  • thiruvenkata
    As I am a beginner, I am feeling difficult to understand what you have mentioned, It would be helpful if you give me a stepwise instruction.
  • RobMan
    I would recommend you take one of the Cadence training courses...
    e.g. Physical Verification Language Rules Writer
    (There was a problem pasting the URL link but you should be able to search for the above from the 'Learning' tab on support.cadence.com.
    Merry Christmas.
  • thiruvenkata
    Thank you, Merry Christmas!!
