  3. 2D Sweep in Spectre Netlist
  • Subscribers 129
  • Views 1964
KC202505278026
KC202505278026 6 months ago
Hi, I want to know how to sweep 2 parameters at the same time in a Spectre netlist.
For example, following is sweep W and L separately:
// DC sweep
dcSweepW dc param=WMASK start=9u stop=0.288u step=-0.01u
dcSweepL dc param=LMASK start=9u stop=0.243u step=-0.01u
Is that possible to sweep all combinations of W and L, like 2D sweep?
Any answer is welcome, thank you.
    Andrew Beckett 6 months ago
    First of all, posting technical questions in the Feedback, Questions and Suggestions forum is not the right place - that's for issues related to the forums themselves. I moved your post into an appropriate forum.
    To do what you want, you need to use the sweep analysis:
    // DC sweep
    dcSweepW sweep param=WMASK start=9u stop=0.288u step=-0.01u {
    You can nest sweep analyses as you want, with the body (in curly brackets) representing the analyses that are repeated for each sweep point.
  • KC202505278026
    KC202505278026 6 months ago in reply to Andrew Beckett
    Thank you very much for your quick and clear response, and for moving my post to the correct forum. Your explanation about using nested sweep analyses in Spectre was exactly what I needed. I appreciate your help.
    Sincerely,
    Chen
